2005 Jeep Wrangler Heater vents
2005 JEEP WRANGLER
GAHRINGER
Heater problem
2005 Jeep Wrangler 6 cyl Four Wheel Drive Manual 139.00 miles
My heater will only work on the defrost selection and not any of the outher selections with the switch.
Dec 2, 2009 at 8:17 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Hello and thanks for the donation!
This could be caused by a vacuum leak in the vacuum lines controlling the blend doors or a faulty blend door actuator. You will need to inspect the HVAC system thoroughly behind the dash to find the cause of this issue.
Dec 6, 2009 at 10:41 PM
