2004 Jeep Wrangler Turns over but won't start
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
HDFIREFTR
I replaced the fuel pump and crankshaft position sensor. After I replaced the fuel pump and got it down off the stands I tried to start it and it ran for about 5 mins and I shut it down to finish wrapping up the job. Then it wouldn't start. I then replaced the CPS and still nothing. I put a scan to it and no codes. It's a 6cyl 4.0. I had swapped around the relays to no avail. Any suggestions would be appreciated.
Jun 6, 2010 at 11:25 AM
CJ MEDEVAC
  • 11,000 POSTS
See my profile, I'm a CJ Guy, I know little about your rig. Thought I might interject something, just to maybe get you on the right track. Saw you had been waitng patiently.
If you can get it in the intake, thru the air cleaner hose, shoot a shot of STARTER FLUID in, just to see if it "Wants to start"---Thus letting you know whether to CHASE a FUEL ISSUE or persue a SPARK ISSUE ( EZer than checking plugs for fire)
'bout all I got !
The Medic
Jun 11, 2010 at 4:03 PM
