2004 Jeep Wrangler THE DASH OIL PRESSURE GAUGE
49,000 MILES • 6 CYL • 4WD • MANUAL
JTK123
Recentley, the oil pressure gauge on the dash goes to low when coming to a stop; resorts back to normal when resuming speed. Just recently had the oil changed; and this hasn't happened before. Thanks.
Aug 9, 2008 at 10:26 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge-if okay replace the oil pressure sending unit-if not could be the oil pump/engine bearings/sludge/clogged pick up screen
Aug 9, 2008 at 10:30 AM
