2004 Jeep Wrangler engine stalling
2004 JEEP WRANGLER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
POOPS
I run a mail route and at or about halfway, (about 2 hours of running and a lot of start and stops) my engine starts to decrease in speed and run rough and if I try to excellerate there's no response and then, it will "catch up" and throw me back against the seat for just a second, and then no response. It just repeats this cycle until finally, it will die and then start but not stay running.
May 25, 2010 at 1:02 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 29, 2010 at 10:46 PM
