2003 Jeep Wrangler Wont srart
87,000 MILES • 6 CYL • 4WD • MANUAL
DUANE_PATTEN
I went to start my Jeep the dash or indicator lights came on turn the key to the start position and nothing. checked to make sure the clutch peddle was pushed in all the way and still nothing. Cecked the fuses took the starter to an automotive store checked it, it works fine put it back in and jumped the clutch saftey switch and still not starting. what else should I check or do?
Jul 12, 2008 at 7:14 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Try the starter relay. It is located on the passenger side fenderwell. Check for voltage on the battery side and on the starter side with an assistant attempting to crank the engine (you should hear it click). Make sure your ground strap for the starter is on tight.
Jul 15, 2008 at 3:04 PM
