2003 Jeep Wrangler Shaking at 60 mph
111,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANN SMITH
When I drive highway speed, 55 - 60, the front end begins to shake. Not all the time, but frequently. It began after a tire rotation. I've had them check the balance, but it still continued this morning.
Aug 26, 2008 at 1:12 AM
BLACKOP555
  • 10,386 POSTS
make sure tires were put on and torqued properly. next thing would be that the tires are worn and you may need an alignment front or back.
causing the worn tires when moved around to be worn wrong causing the problem you described. happens lots.
Aug 26, 2008 at 4:16 AM
