2002 Jeep Wrangler Fog Lights Randomly turn on
66,000 MILES • 6 CYL • 4WD • MANUAL
SHRANDALL
With the lights turned off my fog lights will randomly turn on. If I tap the turn signal\light switch they turn off. If I tap them again they will turn back on. Do I have a bad switch ? It is only the fog lights the have this issue. The other lights are fine.
Thanks
Aug 25, 2008 at 1:59 AM
TDRISCOLL
Have you found the answer to this problem yet? I have a 2002 Wrangler that has the same problem and have not been able to figure it out.
Sep 9, 2008 at 4:34 AM
SHRANDALL
Simple as cake, you have a bad switch. Remove the two screws holding the steering wheel cover fron the consol, unscrew the control mechanism for the lights, pop in the new on....don't forget to pop off the flasher relay and put it on the new controler, and snap on the cover. Tip #1 lower the steering wheel frm the dash for clearence. Tip #2 the locking mechanism for the electrical connections are those little red tabs, slide them back with a screw driver and pull out the plug. the rest is a snap...good luck.
Sep 9, 2008 at 12:07 PM
TDRISCOLL
That is what I thought the problem was but have not had a free second to look into it. Thanks for the info
Sep 9, 2008 at 1:21 PM
