2001 Jeep Wrangler oil prsure
CFIELDS2351
  • 2001 JEEP WRANGLER
  • 4 CYL
  • 4WD
  • 43,000 MILES
Oil pressure is 20psi after warms up starts at 40psi engine temp run 210 is that normal
Tuesday, April 13th, 2010 AT 3:24 PM
JCGUERIN
That is normal operation, when you acelerate the engine builds up more oil pressure, slow down rpms the pressure drops due to the mechanicle pump operation. The gauge on the dash is pretty accurate. If while driving the gauge drops below 20psi then there may be a problem. When the oil is cold it is thicker, causing higher pressure, when hot thinner, . Keep this in mind.
Sunday, April 18th, 2010 AT 6:58 PM
