2001 Jeep Wrangler Help Please
JWADD4
Electrical problem
2001 Jeep Wrangler 6 cyl Four Wheel Drive Automatic
Jeep died on road one day. Cranks but no power to fuel pump and no fire. New Crank Position Sensor,ASD relay and rebuilt PCM but no change.
Jan 8, 2009 at 5:42 AM
MECHCURT
  • 184 POSTS
All the sensors on this jeep run off the same feed from the pcm I believe it is 5 volts. check the hotside of the maf sensor and see how many volts you have there. I had this same problem and the wire was broke in the harness somewhere. I just tied into the wire right off the pc and down into the harness before it split to all the sensors. Hope this helps please let me know. Curt
Jan 12, 2009 at 1:32 AM
