Engine Performance problem
2001 Jeep Wrangler 4 cyl Four Wheel Drive Manual
I just took my jeep to the shop, I had a rear main seal leak, the back was full of oil and it flooded my starter but we also noticed there is oil coming from under a "plate" were the starter wires are mounted in some screws. Where else can oil be leaking? The valve cover gasket looks fine but where else can iold be coming from? The leak is on the side of the engine on the passengers side. of the engine. its a small leak but getting everywhere? Could it still be the rear main seal, possibly or top or coming from a "plate" with a gasket?
Thank you for your help!
Pete
Pete
Dec 2, 2008 at 11:28 AM
