2001 Jeep Wrangler Clutch
50,000 MILES • 4 CYL • 4WD • MANUAL
HELGA33333
I was just driving, switching into second gear and I heard a pop. My clutch was loose after and I could no longer put it into any gear. Does this mean my clutch went out? What else could it be? Around how much would it cost to get it repaired and any good suggestions for places to have it fixed in Salt Lake City, Utah?
Jan 19, 2009 at 12:06 PM
2CARPRO JACK
  • 11,533 POSTS
When you say "loose" do you mean the pedal is on the floor? If not , normal pedal feel but no clutch usually means it is time for a new one.Any fluid leaks on the ground? is the clutch resevoir full? Sorry, no suggestions on shops yet, we are in the process of building a data base. Ask around, word of mouth is usually better than alot of advertising
Jan 19, 2009 at 11:49 PM
