2001 Jeep Wrangler AC is not blowing cool air
2001 JEEP WRANGLER
SALINAS
Air Conditioning problem
2001 Jeep Wrangler 6 cyl Four Wheel Drive Automatic
Where is the low pressure side located...I was going to try to recharge.
Jul 3, 2008 at 1:49 PM
MERLIN2021
  • 17,250 POSTS
On or near the accumulator(aluminum) can be on the low side hose, which is larger in diameter than the high side, the service port is smaller thatn the high side, so you can't put the can on the wrong one! If it's color coded, the blue one is the low side. charge with the can in the upright position!
Jul 3, 2008 at 1:57 PM
