2001 Jeep Wrangler 2001 Jeep Wrangler Engine wont turnover
104,000 MILES • 4 CYL • 4WD • MANUAL
FBK59
I have a 2001 Jeep Wrangler 4cyl. manual.
that wont start. It tries to Turnover but wont fire all the way. any suggestions? spark plugs maybe?
Mar 14, 2010 at 5:38 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 14, 2010 at 10:23 AM
