2000 Jeep Wrangler Stalling
84,000 MILES • 4 CYL • 4WD • MANUAL
PI-RAAT0459
This started a week or so ago. While driving, when i push the clutch in the the engine RPM's drop right down to zero, the engine wants to stall, unless i can get my foot on the gas in time, and if i have to stop at a light or what ever, it is all i can do to keep it running. Not sure what the problem is. Sometimes i can restart the jeep and it will run fine after that, but sometimes it wont. It continues to run extremly rough. Any clues??? I'm stuck...
Jan 15, 2008 at 8:41 AM
  • 75,988 POSTS
Do you have a check engine light? Last major tune-up
Get the idle air control valve/motor and the throttle position sensor checked.
Jan 17, 2008 at 5:30 AM
