2000 Jeep Wrangler rear end noise
2000 JEEP WRANGLER
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
JERRY DRIVER
I have a noise coming from the rear that sounds like the noise from the tires, but when you let off the gas peddle it goes away. it comes is around 25-35 mph. It's not quite as bad around 60mph. but still there, If you move the shifter to neutral it is quite.
Dec 3, 2009 at 7:13 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Noise only with torque applied indicates the pinion and ring gear not properly meshing maybe pinion bearing. Has diff gear oil level been checked?
Hope this helps
Thanks for donate
Dec 4, 2009 at 1:55 AM
