2000 Jeep Wrangler Heat isn't getting hot
63,000 MILES • 6 CYL • 4WD • AUTOMATIC
MUELLER1966
Just replaced the radiator, water pump and thermostat - and I'm not getting any heat. It's blowing 'warm' air and I'm not sure what I need to do.
Jan 16, 2009 at 1:18 AM
MECHCURT
  • 184 POSTS
Sounds like you may have a partially clogged heater core. Try and remove the hoses and blow out the core, this may help some. Worst case is replacing the core. Hope this helps Curt
Jan 29, 2009 at 2:09 AM
