2000 Jeep Wrangler Heat / AC not working
G.WYNNIII
2000 Jeep Wrangler 6 cyl
I was not able to get my jeep to put out any heat. Noticed the temp gauge wasn't getting hot, so I replaced the thermostat, cranked the jeep, and the problem seemed to be solved. Hot air was blowing and temp was back to normal range. I switched off the ignition to clean up tools and when I turned the jeep back on I had no AC or heat. No air is blowing, on any setting: AC, defrost, heat. I would say it's my fan, buit it worked 5 mins earlier. Checked the fuses and they are all good. Any Ideas?
Dec 16, 2009 at 5:18 AM
MICKEY-D
  • 304 POSTS
Seems like a problem with the control panel. Loose wire, or a partially pulled apart plug in connector. Also check for low, or no vacuum.
Dec 17, 2009 at 6:51 AM
