1999 Jeep Wrangler Slippage
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
CLAYMORE48
Slippage at times when going from second to drive; especially when engine is cold. Could this be something simple or am I looking at a major transmission repair.
Fluid is full.
Nov 8, 2008 at 10:59 PM
BMRFIXIT
  • 19,053 POSTS
Jeep require a special ATF fluid
if tranny fluid was added and or replaced
and not the correct fluid was used tranny will act up like yours
check for TCM codes check engine for any vacuum leaks
and be sure its fine tuned
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 8, 2008 at 11:15 PM
