every time i change gears i hear a loud popping noise
Feb 4, 2009 at 5:39 AM
MECHCURT
MEMBER
Can you be a little more specific as to where your hearing the noise from?? It could be alot of things, try and describe it better please. Curt
Feb 8, 2009 at 2:55 AM
PAINTBALLGOD9
MEMBER
ok i just put all new u joints in the cv rear drive shaft , i dont think its coming from the rear-end. but i do think it might be somewhere near my slip yoke , the rear drive shaft has to much play when i turn it counter clock wise. what do u think could be the problem?
thanks , lance
Feb 9, 2009 at 5:01 AM
MECHCURT
MEMBER
Well when you installed the u joints you would of noticed alot of play in the slip joint i would think. Plus unless the jeep has just been used really hard you dont have enough miles on it to have that worn of a slip joint. I dont understand tho all the play in the rear shaft unless there is a problem with the rearend. It may be worth dropping the cover off the rear end and just having a look??? Sorry wish i could be more help. Curt
Feb 9, 2009 at 12:32 PM
