1999 Jeep Wrangler guage problem
BHART42
Electrical problem
1999 Jeep Wrangler 4 cyl Four Wheel Drive Automatic
When I am driving down the road and hit a bump, all of my instruments quit working. If I stop or tap hard on the brakes, they will usually start working. If they don't, I have to turn the car off and restart it.
Feb 15, 2009 at 12:08 AM
MECHCURT
  • 184 POSTS
Somewhere i would say you have a loose connection or a loose ground. More likely just a connection. With the key on i would begin with a wiggle test on the wires coming up from the fuse panel to the gauges. Watch the gauges and just begin to wiggle the harness's under the dash till you get the drop in power. You will just have to keep doing this till you get the loose connection isolated. On my 88 ( and i bellieve this style stayed this way till 95) the gauges are all on a circuit board that over time just gets weak and any flexing of it or bouncing it around would cause the same problem as your having. I believe they changed the dashes in 95. That is where i would start. Let me know how it comes out and if i can do more, good luck. Curt
Feb 18, 2009 at 10:25 PM
CYALL
My 98 did the same thing. Turns out the gage cluster uses little spade connections. There are about 24 of them. I took my instrument cluster out and twisted the connectors a little. Put it all back, and I haven't had a problem since. Took about 30 min.
Mar 11, 2009 at 7:40 AM
