1999 Jeep Wrangler faulty gauges
CHANCHU
Electrical problem
1999 Jeep Wrangler Four Wheel Drive Manual 36000 miles
sometimes when I hit a bump check engine and air bag lights come on. all gauges drop fuel, speedometer,oil, rpm's but engine is unaffected keeps running. instead of mileage I get code nobus5.
Dec 2, 2007 at 8:45 AM
BOLTOM
caused by the pins in the main wiring harness connector on the back of the dash. A new plug runs about $10 dollars but you have to be able to solder all the wires which is not an easy task.
Dec 26, 2007 at 12:08 PM
