1999 Jeep Wrangler Coolant disappearing slowly
12,300 MILES • 6 CYL • 4WD • AUTOMATIC
SARDOIN
1. About 6 months ago got a new radiator, hoses, etc. Full redo.
2. About 4 months ago got overheat indicator. Checked radiator and coolant was low.
3. Brought back to shop to check. Fluid in radiator was dirty/rusty color. They did another cooling system pressure test and there were no leaks.
4. Continue to loose coolant slowly. I add about 1 liter, every 3 weeks.
5. Every once in a while, I get a smell of coolant when I step out of the Jeep. Jeep is running great. Mechanic said that maybe Block is cracked and/or coolant is picking up rust internally somewhere.
I have not brought in yet for full check to investigate this issue more.
I am wondering if Jeep has terminal illness!
Aloha
Shawn
Dec 11, 2009 at 3:45 AM
BLACKOP555
  • 10,386 POSTS
dont know if id go as far as cracked block. but a minor leak may not show up when pressure testing unless the thermostat is opened and vehicle is hot and the metal has moved.
a small trickle on the radiator may not show up either because you are loosing a relativly small amount of coolant. id check around all gaskets or perform a die test on the vehicle.
Dec 11, 2009 at 10:52 AM
