1999 Jeep Wrangler Clutch will not engage
74,000 MILES • 6 CYL • 4WD • MANUAL
TAJIK_BUC
had clutch engaged at a red light, shifted into second, and clutch went all the way to the floor, with much less force required than normal. Had to re-engage clutch due to traffic, but then the clutch would not depress at all. Shifted into neutral and coasted off the side of the road. Any ideas?
Dec 11, 2008 at 7:19 AM
  • 31,937 POSTS
Hi there,
More than likely you have a leak in the hydraulic system, check the fluid level, if empty you will have a faulty slave cylinder or faulty master cylinder this will have to be repaired and the system re bleed of air, check this out.
Mark (mhpautos)
Dec 11, 2008 at 8:16 AM
