1999 Jeep Wrangler car steaming
74,000 MILES • 4 CYL • 4WD • MANUAL
ALOPEZI
Jeep seems to be overheating and the antifreeze completly drained out from under the car.
Jan 14, 2009 at 12:50 AM
MECHCURT
  • 184 POSTS
Can you give some better information. Was it running hot for awhile and then lost all the fluid?? Did it lose the fluid while sitting and running?? Kinda have to get a better idea of whats going on before can answer or give any help. Get back to us please. Thanks Curt
Jan 14, 2009 at 4:33 AM
ALOPEZI
no check engine light on and I hadn't noticed leaking prior, however it has smelled like its been running hot for a couple of weeks. I had only been driving for about 3 miles I turned the corner and it started steaming under the hood and when I pulled over the fluid drained. I put water in last night. I just need to drive it about 2 miles per day for the next 3 days and will get fixed. is that ok?
Jan 14, 2009 at 4:37 AM
MECHCURT
  • 184 POSTS
Well i cant really answer that not knowing where its leaking. If you got to drive it just make sure you fill it up before going and carry some water with you. I dont know how fast your losing coolant or where its coming from. Hopefully you will get to where you are going for repairs. Let us know what they tell you. Curt
Jan 14, 2009 at 2:12 PM
