brake lights on either side do not work. Running lights do work on both sides.
middle high position brake lamp (above spare tire) does work.
examined fuse (20 amp) in glove box area, and although fuse appeared OK, did change out, but no results.
removed both tail light lense covers and cleaned and inspected both bulbs. Both appear OK. Cleaned contacts and replaced. No one to assist, so didn't get a visual if brake lamps might work.
checked back-up lamps and running tail lights. Both work OK.
checked fuse box under hood, but did not bother any of these fuses or inspect them. All seemed to be properly posistioned and making good contact.
This jeep is very clean and do not think any off-road water or dirt, etc. has been confronted. I'm a new owner of less than 2000 miles.
any advice as to why these brake lamps don't work?
Jun 8, 2008 at 6:16 AM
