1998 Jeep Wrangler fuel pump issues
150,000 MILES • 6 CYL • 4WD • MANUAL
71BEANS
  • 5 POSTS
I replaced the fuel pump/sending unit and now it won't start. Do I have to purge the air from the system? If so, how do i do that?
Apr 24, 2010 at 10:35 PM
  • 31,937 POSTS
Hi there.
petrol systems are self bleeding, do you have fuel rail pressure? do you have injection pulse? do you have spark?
mark (mhpautos)
Apr 24, 2010 at 10:44 PM
71BEANS
  • 5 POSTS
The jeep ran just fine before I changed the pump. I was getting a code for bad fuel level, so I changed the entire unit.
Apr 24, 2010 at 11:26 PM
  • 31,937 POSTS
check the fuel pressure at the rail, if no pressure you have an electrical problem , faulty new pump or the lines are back to front, can this happen? are they the same size?
Mark (mhpautos)
Apr 24, 2010 at 11:29 PM
71BEANS
  • 5 POSTS
The pumps were the same. Is the fuel line directional? I don't remember taking it off, but may have and put it on backwards....
Apr 24, 2010 at 11:44 PM
  • 31,937 POSTS
most pumps have 2 lines, pressure and return, some time with a 3 purge line (vapor) we really have to know if the pump is work, can you hear it hum when the ignition is turned on, do you have any fuel pressure?
mark.
Apr 24, 2010 at 11:54 PM
71BEANS
  • 5 POSTS
I do not have a gauge to check pressure. Do I need one? The pump does hum when the ignition is turned on. There is only one line that comes out of the top of the pump and one eletrical connection.
Apr 25, 2010 at 12:12 AM
  • 31,937 POSTS
Take line off fuel filter and check for good flow, that should be enough for now, also check for spark and make sure that the plugs are not fouled up, have you run a scan as yet?
mark (mhpautos)
Apr 25, 2010 at 12:22 AM
71BEANS
  • 5 POSTS
Fixed it. When I installed the "used" fuel pump/sending unit, I never noticed that the pick up tube was broken off inside the short extension tube that conntects to the pump motor. No wonder I was not getting any fuel. Thanks for all of your help today.
Apr 25, 2010 at 12:29 PM
  • 31,937 POSTS
OK, thats good, that was an easy oversight, but it shows the value of checking these things step by step, thank you for using 2carpros, you feedback is always welcome.
mark (mhpautos)
Apr 25, 2010 at 6:41 PM
