1998 Jeep Wrangler Engine running poorly-stutters
1998 JEEP WRANGLER
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
PROUDPAPA
My 1998 Jeep Wrangler is running rough after 1 mile of driving. I have changed or inspected the following:spark plugs, spark plug wires, distributor, all the sensors that are on top of engine, and the sensor in the distributor cap. Fuel pressure is good, fuel injectors are good. No codes show up or check engine light comes on. I am BAFFLED!!!!!!! The car will almost die unless I stomp on the throttle and that helps, but as soon as I let off the gas it will start sputtering again.
Any help will be greatly appreciated.
Aug 27, 2008 at 10:38 AM
MOOSEMAN1257
My TJ is doing the exact same thing. It only does it for a minute or two then its fine, with the occassional wanting to stall at a light, but I just bump the throttle and its fine. I am also extremely baffled and frustrated! Good luck and if you figure anything out please let me know what it is.
Thanks
Matt
Oct 1, 2008 at 3:40 PM
