1997 Jeep Wrangler Starter
14,000 MILES • 4 CYL • 4WD • MANUAL
D_BLACK
When I attempt to start the vehicle all I get is a "Click". The battery tested out good. Is this most likely a selonoid problem? Is there a second firewall mounted selonoid other than the one mounted on the starter? If not can the selonoid only be replaced or do I have to replace the starter?
**2/07/09 It was the starter. I had the starter rebuilt, Half the price of a cheap rebuilt one from Advance and its the original starter. Plus the guys that did the work have been in business 36years (The Generator Shop, Gastonia, NC) I would recommend them to anyone!!
Feb 4, 2009 at 11:35 AM
MECHCURT
  • 184 POSTS
I would agree that it is probably a selenoid problem. There is only one and it is on the starter. You can take the starter off and use a battery charger to test it and make sure it engages. Also i would get a starter from autozone with a lifetime warranty. They are not that high and you will only have to pay for one in case it goes out in the future. Curt
Feb 8, 2009 at 3:44 AM
