1997 Jeep Wrangler Poor gas milage, rough idle, check engin
1997 JEEP WRANGLER
OLRNDRT
Engine Performance problem
1997 Jeep Wrangler 6 cyl Four Wheel Drive Manual
Had been operating normally. While on the interstate, check engine light came on. Except for rough idle, every thing seemed normal. After approx. 100 miles, noticed fuel consumption was very high. At end of 400 mile trip consumption had more than doubled. Clerk at Auto Zone read computer codes. Said there was a vacuum leak. I checked all lines and manifold gasket with aerosol solvent. Found no leaks but did find crank case vent open in both directions. Repair manual states that, on this mod., the PCV was replaced by A CCV which has the same function and is tested in the same way.. Auto Zone and NAPA can not find this change in their computer and found no PCV for this engine. The unit which I believe to be defective looks exactly like the photo in the manual. I have eliminated this part by capping the vacuum line at the manifold. Check engine light is still on.
Could this part cause the symptoms described?
Does the computer need to be reset to turn off the light when the problem is repaired?
If this is not the actual problem then what should I check?
Apr 29, 2008 at 9:59 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Since the advent of the wranger pcv systems are not a part of the emission system. CCV or Crankcase ventilation is continuously running and will pull vacuum all the time from the valve cover. Make sure the gasket on your valve cover is ok. Get a vacuum guage connect it to that line you disconnected and see what happens. It should be hovering steadily around 17-20 inch. vac. at idle. Make sure your EGR works correctly otherwise that will cause all kinds of problems. Let me know if you get any other readings or what kind of readings you get. (I.E. moving up and down, erratic, and under what conditions)
May 5, 2008 at 5:35 PM
OLRNDRT
Thank you very much for your response. Never found a vacuum leak. Cleaned and reinstalled CCV. Do not think this was the problem. Cleared the computer. After several days of operation check engine light never came back and fuel consumption is now normal. Not good but normal.
If you can't be good, BE Lucky.
May 7, 2008 at 3:03 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Have you replaced the O2 sensor? They only last 30,000 miles. Reset the MAP sensor too on the firewall. If neither of these help then you could check the catalytic converter or the operation of the EGR.
May 8, 2008 at 7:31 AM
