1997 Jeep Wrangler no ground A8 fuel pump relay
1997 JEEP WRANGLER
DJ_DEJAGER
Computer problem
1997 Jeep Wrangler 6 cyl Four Wheel Drive Automatic
1997 Jeep Wrangler no ground to fuel pump relay A8 from PCM what inputs to PCM controls this function? Is it possible to download a flow diagram for the fuel delivery system for this vehicle?
Mar 22, 2010 at 9:25 AM
A8 is a power circuit that comes from fuse 11 10amp and powers the coil side of the fuel pump relay, fuel pump and the Evap solenoid, also check fuse 18 20amp this is the one the powers the switch side of the fuel pump relay
Mar 22, 2010 at 10:28 AM
