1995 Jeep Wrangler Water in my oil
160,000 MILES • 4 CYL • 4WD • MANUAL
KELLYBOOK
Help! I have water in my oil. They drained, flushed, sealed, but it's still happening. There is not water leaking (on to the ground) from the radiator BUT after a short time even when just parked it needs more water. How can this be happening???
Broke and in trouble...
Kelly
Feb 25, 2009 at 2:18 AM
MECHCURT
  • 184 POSTS
Sounds like you have a head gasket leaking. Allowing water to get into the oil. The oil on the dipstick will turn milky afterawhile and you will notice this on the underside of the oil fill cap after some time. This is about all i can tell you without an update. Hope this helps Curt
Mar 21, 2009 at 4:26 AM
