1995 Jeep Wrangler Skid Plate
117,000 MILES • 4 CYL • 4WD • MANUAL
BEMISH410
What's the best way to remove the skid plate? It seems real heavy and the Transfer Case sits on top of it.
Is the Transfer Case attached anyplace else besides the Skid Plate?
Feb 28, 2010 at 4:35 AM
CJ MEDEVAC
  • 11,000 POSTS
See my profile.....On a CJ tranny and transfer case are bolted together and ONLY the transfer case bolts to the skidplate. .......Removal is EZ......Jackstand up tight against rear driveshaft, close to skidplate...(if your drive shaft is on really steep angle, center up a jack to support plate, unbolt it, lower every thing at once, until JACKSTAND SAFELY will support shaft at a safe level attitude)...this will support weight of all....... Tranny/ transf. case/ rear of engine...........Engine + mounts will prevent TWISTAGE of entire assembly while you drop plate.... If you are dropping all at once---take care not to BIND-UP your STICK-SHIFTERS and any thing else that may touch as you lower..... SOUND LIKE A SAFE METHOD?...ANY THING YOU ARE UNSURE OF?......NOT AS BAD AS YOU THINK......TAKE IT SLOW.....HELP IS ALWAYS A PLUS.....Wadder you doing anyway? Love, Turddog
https://images.2carpros.com/forum/automotive_pictures/411289_100_0327_1.jpg
Feb 28, 2010 at 11:37 AM
