1995 Jeep Wrangler Fuel Pump
CAROUSELTRAVEL
Engine Mechanical problem
1995 Jeep Wrangler Manual
Do you know where the fuel pump is located on a 1995 Jeep Wrangler?
Oct 30, 2008 at 1:03 AM
REDJEEEP
  • 29 POSTS
it is located in the gas tank
side note that year jeep might have a recall that has to do with the fuel pump but it does not include replacement call your dealer give them you vin and have them check if not in order to replace the fuel pump you will need to remove the fuel tank (danger fumes can kill ) i would recomend that you have it done by a shop
i hoped this helped if not or if so let me know
Nov 1, 2008 at 3:35 AM
