Engine Mechanical problem
1995 Jeep Wrangler 4 cyl Four Wheel Drive Manual
I have a 1995 Jeep Wrangler that runs good when it is running, but the problem is when you turn it off. When you turn it off and it sits for 5 minutes or so and attempt to turn it back on, it won't start. I've inspected it and what's happening is when you turn it off, the fuel drains back out of the fuel pump & all injectors and goes back into the tank so essentially it drains all of the fuel. However, if you wait another 2-5 minutes later, the fuel pump kicks back on, circulates the fuel and the Jeep will start right up.
The Jeep has a new fuel pump, filter, pressure regulator & fuse. Does anyone have any ideas as to what it could be? Thanks! Any information would be appreciated!
Dec 18, 2009 at 7:22 AM
