1995 Jeep Wrangler Door Lock Problem
12,200 MILES • 4 CYL • 4WD • MANUAL
NERO60
Both driver and passenger side doors can be locked with key from exterior. However, unable to unlock doors with keys from exterior.
Feb 1, 2009 at 8:01 AM
MECHCURT
  • 184 POSTS
Are the lock cylinders in the door vertical and straight up and down?? Sometimes the cyl's turn in the door and therefore takes all the movement in that direction away from the key. Meaning you can turn the key one way but not the other. Hope i made that understandable. If they cyl's look like they are in the right position than i would pull the door panel and inspect the operating rods for the locks. Hope this post helps and please advise as to what you find. Curt
Feb 8, 2009 at 3:16 AM
