1995 Jeep Wrangler back up
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
SINFULRIDES32
i have a 95 jeep wrangler
the back up lights dont work
i changed the bulbs and checked the fuses we also put a new switch in the transmission i am in a corner and dont know what else to do with it.
i will greatly appreciate any and all help
Mar 14, 2009 at 12:34 AM
2CARPRO JACK
  • 11,533 POSTS
Check the dark blue/white wire on the trans switch for power with key on.If no power check fuse 9 (15 amp) if ok and has power the violet wire on the neutral safety switch(trans) should go hot when in neutral, if not the switch is bad. If it does there is a probelm between the switch and bulbs.
Mar 14, 2009 at 1:39 AM
