1995 Jeep Wrangler
1995 JEEP WRANGLER
DEDGETT
Engine Mechanical problem
1995 Jeep Wrangler 6 cyl Four Wheel Drive Manual
I just replaced the radiator...it was very simple. I went to go start the Jeep and now I get nothing...it is turning just never starts. I can not figure it out because I literally didn't touch anything else. Any thoughts
Jul 23, 2008 at 5:22 AM
Do below to determine if its fuel or spark.
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Jul 23, 2008 at 5:52 PM
