Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Wrangler
Drivetrain
Transmission
Clutch
Slave Cylinder
1995 Jeep Wrangler
1995 JEEP WRANGLER
126,000 MILES • 4 CYL • 4WD • MANUAL
FSOWELL
MEMBER
1 POST
need to know how to fix the slave cylinder
Apr 1, 2009 at 10:27 AM
BLACKOP555
Experienced Mechanic
what is wrong with it?
get a rebuiild kit and it should fix most problems.
Apr 4, 2009 at 8:10 AM
MECHCURT
MEMBER
Not to take away from the prior post. Just replace the slave cyl they do not make a kit for it as far as i know. Thanks Curt
Apr 16, 2009 at 5:46 AM
BLACKOP555
they should have a kit. check with your local jobbers. it is best to replace to same time. but if money is tight...
Apr 16, 2009 at 7:27 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
