1994 Jeep Wrangler Strong fuel odor
134,000 MILES • 6 CYL • 4WD • AUTOMATIC
AFHANSON72
I am getting a strong fuel odor from the throttle body. It happens after it runs for 5 or more minutes when the engine is running or turned off. When the engine is turned off after it has run for a while and is good and hot I hear a bubblig sound from inside the throttle body.
Jul 5, 2008 at 4:41 PM
  • 75,988 POSTS
Injector/s could be stuck open or the pressure regulator is leaking. Also I recommend you check the fuel pressure.
Jul 5, 2008 at 4:47 PM
