1994 Jeep Wrangler Replacement of leaf springs
JEEPSOFTTOP
Suspension problem
1994 Jeep Wrangler 6 cyl Four Wheel Drive Manual
I have a 94 jeep wrangler 4x4 manual. The other day i hit a low wall that bent my front drivers side leaf spring.Now do i replace the leaf springs or can i mount heavy duty shocks in the front removing both front leaf entirely but leave the rears in place. Can i do that or do i need the springs even with the shocks.
Jun 13, 2009 at 3:50 AM
  • 110,244 POSTS
You need to replace the leaf springs. The coil over shocks are only to help for loads. You can't remove the leaf springs. Also, I recommend replacing both sides to maintain the same height.
Jun 29, 2009 at 3:18 PM
