1994 Jeep Wrangler engine knocks
180,000 MILES • 6 CYL • 4WD • MANUAL
BRETTAB
engine knocks bad when over 1.5 rpm what could it be then the oil pressure drops to nothing but if I dont rev the engine over 1.5 rpm the oil pressure stays up and the engine doesnt knock or diesl, any help would be thankful.
Jan 17, 2008 at 1:29 AM
  • 75,988 POSTS
If the noise is more like a thudding noise its your rod bearings if its thumping type-main bearings-either way it has to be checked. If not checked-could throw a rod and its all is over. New engine
Also might want to actually check the oil pressure-who knows could be the oil pump going southbound.
Jan 17, 2008 at 5:26 AM
