1994 Jeep Wrangler Clutch
1994 JEEP WRANGLER
191,000 MILES • 4 CYL • 4WD • MANUAL
JEEPWRANGLER94
My jeep has a burned out clutch. I was wondering how difficult it would be to change it? I know this can be difficult on some other larger suv's, but the jeep is tiny and easy to work on, just wonderin
Jan 15, 2009 at 9:25 AM
MECHCURT
  • 184 POSTS
Its not that bad. doing it the first time?? Safety is the biggest thing. Make sure you have it blocked up properly and use a tranny jack if you can. Also replace everything while you are in there. The clutch and the throw out bearing also the pressure plate. Check the flywheel for cracks and burn marks. You may need it resurfaced. Also make sure to use a clutch alignement tool and double check to make sure you install the clutch plate the proper direction lol, take your time and you should have no problems. Curt
Jan 29, 2009 at 2:16 AM
