1993 Jeep Wrangler water pump and belt
1993 JEEP WRANGLER
13,000 MILES • 4 CYL • 4WD • MANUAL
MAVERICK11
how much is it to replace a water pump and timing? belt
Jan 25, 2009 at 4:58 PM
MECHCURT
  • 184 POSTS
The labor should not be more than two hours and if i was you, just call the shop and ask on the price for the parts. Then check with autozone and see what they cost you. It may be cheaper to take the parts with you. You will also have some cost in antifreeze. Hope this helps Curt
Jan 29, 2009 at 9:41 AM
