1993 Jeep Wrangler water in the engine
1993 JEEP WRANGLER
SMOKEY1977
Engine Mechanical problem
1993 Jeep Wrangler 4 cyl Four Wheel Drive Manual 119k miles
yes i went fishing not about a week ago and i got stuck in a water hole and the jeep died and wouldnt start intell i got it outof the water it took a whille to get it started i was woundering what i need to do to fix it i know that i have to replace the oil and drop the oil pan and wipe it out please tell me what else need to be done
Jan 29, 2009 at 8:13 AM
  • 31,937 POSTS
Hi there, i would be replacing all the transmission & diff fluids as well, there should not be a need to remove the sump, a flush and filter change will do, may be do a flush with a cheap engine oil first then re drain and fill up with your normal oil.
Mark (mhpautos)
Jan 29, 2009 at 8:24 AM
