1993 Jeep Wrangler NO BRAKE PRESSURE
13,000 MILES • 6 CYL • 4WD • MANUAL
SWEETNESS
I HAVE REPLACED THE BRAKES AND BLEED THEM SO MANY TIMES AND STILL HAVE NO PRESSURE IN THE PEDDLE. WHAT DO I DO?
Mar 5, 2008 at 11:29 AM
SERVICE WRITER
  • 9,123 POSTS
When you replaced them, did you open the hydrolic system anywhere before bleeding?
Was there a pedal before replacing?
Get a couple plugs to seal off the master cylinder from the rest of the system. With plugs in the lines holes the pedal should be high and hard. If not get a master cylinder. CHECK IT FIRST!!
Mar 5, 2008 at 11:48 AM
