1993 Jeep Wrangler High oil pressure???
1993 JEEP WRANGLER
90,000 MILES • 4 CYL • 4WD • MANUAL
DREADLOCKSRLOVE
I just purchased a 1993 Jeep Wrangler yj, 4cyl. 90,000 miles. Runs extreamly well, but instantly when i start the engine the oil pressure guage reads 80. I've been told several different things from different sources. I"M CONFUSED NOW!!! is this something that i need to fix? how do i fix this?
Jan 20, 2008 at 9:07 AM
Find the oil pressure sending unit-remove and hook up an oil pressure tester to it and read the oil pressure-if its normal-replace the oil pressure sending unit. If its too high-check the oil pressure relief valve on the oil pump.
Jan 20, 2008 at 9:38 AM
