1993 Jeep Wrangler Difficulty shifting
103,000 MILES • 4 CYL • 4WD • MANUAL
IANIDBAR
My Jeep is in great shape and it runs really well, considering its age. Recently it has become difficult to shift into first gear from a complete stop, and second gear is also pretty hard to shift into. Sometimes if I'm rolling slightly it's a lot easier to get the transmission into first gear. I think the clutch is fairly worn--it engages very high and tends to shake/shudder when cold. I'm wondering if the problem is with my clutch or with my transmission, and how serious it is.
Jul 10, 2008 at 6:12 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:32ef813211="ianidbar"]Transmission problem
1993 Jeep Wrangler 4 cyl Four Wheel Drive Manual 103000 miles
My Jeep is in great shape and it runs really well, considering its age. Recently it has become difficult to shift into first gear from a complete stop, and second gear is also pretty hard to shift into. Sometimes if I'm rolling slightly it's a lot easier to get the transmission into first gear. I think the clutch is fairly worn--it engages very high and tends to shake/shudder when cold. I'm wondering if the problem is with my clutch or with my transmission, and how serious it is.[/quote:32ef813211]
Manual trannies are pretty tough. So I would suggest checking the Clutch Master Cylinder and the Clutch Slave Cylinder for Leaks. If all is good there then would recommend replacing Clutch.
Jul 10, 2008 at 11:34 PM
