HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Wrangler
Drivetrain
Transmission
Clutch
1993 Jeep Wrangler clutch
JEEP042392
MEMBER
1993 JEEP WRANGLER
6 CYL
4WD
AUTOMATIC
10,000 MILES
The clutch is not let me put it in gear what could be wrong
Tuesday, June 8th, 2010 AT 1:34 PM
CJ MEDEVAC
MECHANIC
See my profile, Check the following:
See if any linkage, at the bellhousing is bent, broke, missing.
You may have to bleed air from the clutch system.
Your Clutch "master cylinder" may be defective and require replacement and bleeding.
Your "slave cylinder" may be defective.
The Medic
Thursday, June 10th, 2010 AT 11:44 PM
Please
login
or
register
to post a reply.
Related Transmission Clutch Content
Clutch
My Jeep Is Not Go Into Gear
Asked by
lvonda785
1993
JEEP WRANGLER
VIDEO
How to Check Your Clutch Operation?
Instructional repair video
GUIDE
Clutch Replacement
Before you replace your clutch its a good idea to see how the clutch works and the symptoms of a bad clutch. A clutch will have problems and can stop working all...
Clutch
Clutch Went Out And Tried Putting Brake Fluid But All Leaked Out Under The Car
Asked by
samanthadeherrera
1998
JEEP WRANGLER
Stall When Clutch In
1990 Jeep Wrangler 6cyl, 135,000kms Stalls Out When I Come To A Stop And Put The Clutch In. Rpms Drop To Zero And It Stalls Out. It Will...
Asked by
sam_w79
JEEP WRANGLER
Now I Have To Pump The Clutch To Get It In Gear.
Just Bought A 1994 Jeep Wrangler Yj. It (manually) Shifted Fine. Suggestions? I'm Hoping To Be Able To Fix This Problem Myself. If I Pump...
Asked by
tddk1008
1994
JEEP WRANGLER
2005 Jeep Wrangler 2005 Jeep Wrangler
I Have A 2005 Jeep Wrangler, With A Six Speed Manual Transmission. I Bought It Used And It Has Run Fine Until Now. I Was Drining Home From...
Asked by
JPHains
2005
JEEP WRANGLER
VIEW MORE
Clutch and Throwout Bearing Front Wheel Drive
Clutch/Flywheel/Rear Main Seal Replacement
Clutch - How it works
