HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Wrangler
Warning Lights
Check Engine Light
1993 Jeep Wrangler check engine light is on
RICHARDNOGIN
MEMBER
1993 JEEP WRANGLER
6 CYL
4WD
MANUAL
16,500 MILES
I want to know how to find out how to use a paperclip and jump my computer to tell me what is wrong
Tuesday, September 15th, 2009 AT 5:46 PM
BMRFIXIT
MECHANIC
Cycle ignition key on off on off on check engine light should blink the code (* ** codes 12 )
(***** ***** code 55)
Tuesday, September 15th, 2009 AT 5:54 PM
MECHANIC
You need a DRB II to pull the code/s from the computer or you can go to Autozone its free service maybe they can help
Tuesday, September 15th, 2009 AT 6:07 PM
Please
login
or
register
to post a reply.
Related Check Engine Light Content
1998 Jeep Wrangler No Power To Pcm, No Check Engine...
I Just Bought This Jeep With Current Issues. The Jeep Will Spin Over Fine, Will Display Odometer Reading In Dash And Show Brake Light And...
Asked by
mdantel
1998
JEEP WRANGLER
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
2002 Jeep Wrangler Check Engine Light
My Check Engine Light Keeps Going On The Code Is Low Volts Tps(but Ive Changed It Out Twice And Still Have The Same Problem(when Ive Been...
Asked by
one2exile
1 ANSWER
2002
JEEP WRANGLER
Bought My 2002 Wrangler Two Days Ago. Went To Buy New Tires And Wheels. On The Way Home, The Check Engine Light Started Blinking. Within A...
Asked by
ridezlow
2002
JEEP WRANGLER
2001 Jeep Wrangler Check Engine Light
Radiator Has Been Replaced, Water Pump, Starter. Had A Compression Test Done. No Issues. Yet I Am Still Losing Coolant. Today The Check...
Asked by
autumnsage67
5 IMAGES
2001
JEEP WRANGLER
1997 Jeep Wrangler Check Engine Light
I Have A Check Engine Light On, Code Read The Bank 1 Running Lean, But It Was Not Running Lean, I Had Black Smoke Come Out Of Tail Pipe. The...
Asked by
dfort233
1997
JEEP WRANGLER
VIEW MORE
Code Read Retrieval/Clear Chevrolet
Check Engine Light Safe to Drive?
