What must be removed to replace the windshield cowl seal
NIGHTMEDIC
What must be removed to replace the windshield cowl seal? Can it be done by just removing the winshied inside bracket torx bolt? and roll cage top torx bolts? Or must I remove the hinges and wiper assemblies etc?
[img:75485c37ce]http://www.2carpros.com/forum/automotive_pictures/98664_wrangler_1.jpg[/img:75485c37ce]
1992 Jeep Islander, 4.0 HO engine 164K miles 3.5 inch lift (shown with 31" tires for street)
Sep 8, 2007 at 3:45 AM
SQM
  • 6,383 POSTS
It will be ideal if the wiper arms get removed. This will make it easier to do the install.
Keep in mind that it is important to prep the surface before installing of the new seal.
Make sure there are not dirt of debris in the channel where the seal will go in.
Here is a helpful video of how to remove wiper arms:
https://youtu.be/4YhpeoZoKu8
Oct 28, 2021 at 3:30 AM
